I have a 1983 ASTROGLASS 15.4 FISH & SKI
petef58
I?m new to iboats
I have a 1983 ASTROGLASS 15.4 FISH & SKI it is a modify V Hull bottom
I need to remove the top cap off the boat
I have removed the r rail & ribits and pull up on the top but it don?t wont it come up what am I doing wrong
how can i find the tabs on a modify V bottom Hull.
i move the batts and look down under the livewell i see nothing holding it down?
Bob_VT
Re: Flat Foot
Re: Flat Foot
Welcome to iboats. Tell us more about your project.
You are on the right track. Sometimes it takes a bit of persuasion with a hammer and a block of wood.
It is not uncommon that boat builders slap some resin between the pieces and even use fiberglass tabs during assembly. I will move this to the Restortatioin section and you will get more answers
Consider using a thread title that makes sense to the iboats members!:rolleyes:
Bob_VT
Re: Flat Foot
Re: Flat Foot
Good title change :) You need to be creative it the cap removal. Some people her have used wood blocks, wood wedges, sometimes it requires a utility knife to score and slice through tabs of fiberglass. The key is to be persistent.
Have you read through the "big thread" http://forums.iboats.com/showthread.php?t=234392 that has been posted by Oops..... full of great information on fiberglass work. We even have a member doing a 32 ft Donzi who faced the same problem.
Bob_VT
Re: I have a 1983 ASTROGLASS 15.4 FISH & SKI
bump for help
tallcanadian
Not sure what all you have done but I used a wooden wedge and went around the perimeter of the boat. Also the transom may be glassed to the cap like mine was. Also I had six strips of fiberglass attaching the cap to the hull on the inside of the boat, under the cap. Hope this helps.
