I Found a Great Vinyl Cleaner!
LagunaBlue
Hello All,
Some of you may have already discovered this, however, I wanted to share with everyone a great product (which I have no affiliation with) for cleaning up heavily soiled vinyl upholstery and tops.
The previous owner of my '98 Maxum had the boat sitting outside for a few months during a very rainy spring with only part of the camper top fitted. The seats and side panels, as well as the white camper top, had quite a bit of mildew and deep grime embedded into the white, burgundy, & tan vinyl. I had purchased some Meguiar's Boat/RV Vinyl Cleaner after hearing good things about it. Well, it did nothing, and I mean nothing, to clean up the vinyl. I might as well have used water.
However, I've been cleaning the all white vinyl in my Donzi for years using Tilex Mold & Mildew Remover and it works wonders, however I was a bit apprehensive about using it on tan & burgundy vinyl due to [its] bleach content. Well it cleaned up the white vinyl camper canvas and it looks brand new. And it also cleaned up all of the deeply soiled white, tan, & burgundy vinyl on the seats and side panels with ease! It was as easy as spray on, let sit for about 1 minute, then it literally just wipes all of the mildew and grime rite off. The bleach content did not discolor the burgundy and tan vinyl whatsoever. And everything smells super clean as well :D
Anyway, just wanted to share for those who may be having trouble cleaning up their heavily soiled interiors or tops.
Best,
-Mark
pckeen
Re: I Found a Great Vinyl Cleaner!
Thanks - I have some older vinyl seats that I'm trying to keep for a short while, before restoring the boat. I'll try this.
scottmm73
Just make sure you rinse it completely and thoroughly. I hear the problem with Tilex Mold and Mildew (I use it) is what it does to the thread, it will deteriorate it if not rinsed as stated.
sevanseriesta
I have a popup camper with a canvas top that I might try this on... Interesting. Thanks for the info.
Woodonglass
True it will clean the vinyl, but...It will also remove ALL the UV and other protectants on the vinyl. Make SURE to treat the vinyl after cleaning with this harsh cleaner. I highly recommend you investigate the various 303 Vinyl Products. They absolutely are the best out there....Products
Yacht Dr.
What about the "red stain of Death" .. LOL ..
If you have that solution please post up again :) ..
YD.
jimmy wise
I use Malco vinyl cleaner its great stuff.
Yacht Dr.
Does it get rid of the "red stain" ?
I dont think Iboats has come across a cure for the Red/Pink stains.
Some say its the vinyl while others say its the Foam that causes the problem.
If its just scuffs and lotion stains.. then yea you can remove it with a Magic pad and some soft scrub. .. rinse well after application.
If its Imbedded into your fabric then your boned.
YD.
jimmy wise
I don't know...is the red stain right before the vinyl cracks. Gas and a match
