Hydraulic ram stuck on pin
beruken
Trying to remove the hydraulic rams and pin form my transom assembly and they won't free. WD-40'd and light hammering/prying, nothing. Seem to be fused with the plastic bushings and really don't want to snap the transom/gimbal assembly by hammering too hard. Can they be heated to melt the plastic sleeves?
Bt Doctur
LOSE the HAMMER Get your self a pitman arm puller and slightly modify the ends to fit behind the cylinder. once removed use a 3/4 inch plumbers wire brush to clean the insides of your clyinger untill the bushings slide right in
beruken
too late. metal hammer on metal worked. suspect it has been 25 years
