hull drain
huey3160
I am new to the forum so please be patient with me lol. I am the new owner of a 1970 stuery 16 ft runabout. I replaced the deck on it and being an auto body guy am confident in the job I did... however after pulling up the old deck I noticed there were no drain holes through the stringers to the bilge to allow the hull to drain. I replaced the deck anyway without drilling any holes. I am sort of regretting that decision but it has been glassed and too late to do now. My question is I would like to put 3 holes in my deck, over the 3 sections of the hull so that I can inspect for water and pump it out if it gets water in it. Is this a good idea and if so, do they make a kit for it. Maybe something. that is flush mounted and maybe 2" in diameter.
Woodonglass
Honorary Supreme Mariner
Re: hull drain
I'm thinkin you could still drill drain holes in the bilge that would drain the hull. Post some pics of your bilge so we can see.
huey3160
Re: hull drain
There is one hole to the bilge but the aft stringer blocks the forward hull area from draining. The deck plates are a great suggestion. Thanks for the input. Great forum!
Woodonglass
Re: hull drain
One hole??? That's to drain the bilge out of the transom...Right? If you put the stringers in, what is the configuration of them as they attach to the bilge?
