How to measure voltage from stator to switch box
ARTHURRUF
I have a 50 HP 4 CYL 1983 Mariner outboard with electric start. I get no spark at the plugs so I want to find out if alternating current is going to the switch box from both the stator and the trigger. How do I do this? I also want to know if direct current is going to the coils from the switch box. How do I do this?
Thnks, Art
Texasmark
Re: How to measure voltage from stator to switch box
Not being sarcastic but get a manual. My manual outlines the process for my 3 cyl 90 hp but the 4 cyl is a carryover from the cross flow original days and may have been updated differently than an engine that was designed with current technology.
Mark
CharlieB
A DVA meter or a DVA adaptor for use with any volt/ohm meter is a GOT TO HAVE item in order to troubleshoot an ignition system.
Without it you can spend a lot of money replacing parts that you 'think' might be the problem.
Download the free CDIelectronics ignition troubleshooting guide.
Somewhere in this forum you will find the directions to build your own DVA adaptor easily and surprisingly cheap.
