How soon can I epoxy & glass over 5200?
Backyardhockey
Hello. Just finished replacing a small section of my deck. Used 5200 to bond to some joists I sistered in and to seal a couple of small gaps. How soon can I use epoxy resin and fiberglass over the 5200? Package says it cures in 7 days! Is 24 hours too soon? Also, Should I screw the new piece down or will the combo of 5200 below and glassing in from above be enough?
erikgreen
Re: How soon can I epoxy & glass over 5200?
5200 cures in the presence of water, so moisture in the air is a factor I think. I'd wait if you can.
Sounds like you used 5200 to glue down the deck, did you use it to attach stringer parts too?
Erik
Backyardhockey
It's a 15" x 26" repair on a soft spot. Stringers were fine. I sistered in(screwed) wood to the stringers. Put 5200 on the sistered wood. Deck was 1" thick in this area (over the gas tank). I used two pieces of 1/2".
erikgreen
Okay, so you sealed the screws in, then? Sounds okay.
Good for a couple years' fix, anyway :)
Erik
Yacht Dr.
Hello Backyardhockey..
Glass it m8.
YD.
PS.. GO WINGS .. :)
Backyardhockey
Thanks for the replies. I called 3M. They said I should hold off glassing for a week, but I can use the boat this weekend. I'll just cover the area for now, though it looks like rain for the weekend. I couldn't believe how quickly I was in touch with somebody who knew what he was talking about at 3M. I just called the main number. He did say they have a quick-cure version of 5200. Wish west marine carried that!
Dr.; I grew up in the city durring the dead things time. Sure hope #13 is in the lineup on Sat.
salty87
home depot has 5200 for a fraction of the price of WM
