how much oil in gear box
zeber
i have a jonhson 25 hp motor how much gear oil do i need to put in, do i feel it to the all the way full or what thanks
kbait
Re: how much oil in gear box
Add from bottom hole until it comes out of top hole. Fill 'er up!
robert graham
Pump oil in the bottom hole until it starts to come out the top hole, replace plugs, oil level is just right. Don't over fill, need room for expansion. Good Luck!
Fl_Richard
My 150 takes 33 ounces. I'm sure one 32 ounce bottle will be ample. Buy the good stuff.
ezeke
The manual says 8.3 ounces, "Drain and refill every 100 hours of operation or once each season, whichever occurs first." Page 1-50; manual #394607.
1946Zephyr
One little tip:
when you see oil run out the top hole, put the plug in tight and you won't loose any oil when you remove the filler hose from the bottom. :cool:
