How much material to order?
Jeep304
Re: How much material to order?
cant wait to get my goodies!!!!!!!!
Jeep304
Do you use regular sized 4 inch rollers or the minnies
Jeep304
Just received all the material from US Composites, heres my work area. Have a nice floor fan for venting fumes without sucking out too much heat.IMG_20130215_175704.jpgIMG_20130215_175716.jpgIMG_20130215_175743.jpg
StevenT
Nice glass cutting setup. I think I'll do something similar.
JASinIL2006
The mini rollers work great, especially for getting into corners and angles. I think my bubble roller is 4" wide. Bigger would be handy if you were doing a lot of glassing of big deck areas, but the 4" one works fine, I think.
Jim
Jeep304
Just wet out some wood. Went petty smooth for first time. Hopefully a good mix with hardener. Should have kept the respirator on longer, dont know if its the Lite or the fumes.
Yacht Dr.
Fumes will consume ..
Its probably the Lite beer however .. be careful of both intakes :) .
YD.
Woodonglass
Just make sure NOT to try and Thin the Resin with Budweiser!!!:eek::faint2:
carribbean soul
looking good so far, how is the transom did you check it for rot?
Jeep304
Transom and cuddy checked out good. Heres some pics. Just pl'd in the pieces, now start paying to heat the garage all the time.IMG_20130219_194928.jpgIMG_20130219_194958.jpgIMG_20130219_195015.jpg
Jeep304
The deck is finally waterproofed underneath, glued and stainless screwed.20130318_160241.jpg20130318_160241.jpg
Jeep304
The deck is CSMd. How many coats of 1708 should be applied, and should i screw the seat bases in or should i just fiberglass them. Got some killer factory seats for the boat from Kendor in Franklin WI. boat wholesale. cheap! Phone acting up cant up load pics.
Woodonglass
What surface are you going to finish the deck with? Really no need to use 1708 on the top of the deck. Way Overkill IMHO. Couple of layers of CSM and a final of 6oz cloth is the maximum needed. I would Tab it to the sides with 1708 but that's the only place I'd use it.
"Fabricating Decks, Stringers, and Transoms"
Jeep304
Already tabbed with 1708. Unfortunately already cut to fit 1708 for one coat on deck and have one coat of CSM under that. Is that enough?
Bomber Goober
You could just save it and use it for the next boat ;) I plan on using two layers of CSM on my deck and then gel coating it. I didn't see it mentioned or pics, but did you use foam under deck?
Jeep304
Thanks Wood
Should i screw seat bases in or fiberglass?
Jeep304
yes i foamed under the deck, and havent decided if im going to gel, carpet or nautalex for a finish
