mhcooper84
Thread starter- Joined
- Mar 2, 2012
- 44
to see if they are going bad
82 evinrude 70hp and the problem is it goes fine for about 15 mins and I stop then wait about 10 to 15 and try to start it and it wont crank easy and I cant get it above 2k rpms
Look under the flywheel at the stator. There are three large coils within that ring that deliver approximately 300 AC volts to the powerpack in order to energize the ignition. Should is be starting to melt down for any reason, it might act normal when cold BUT after it heats up, a voltage drop would exist that would result in weak, erratic, and eventually no ignition.
Should this melt down be taking place, a sticky looking substance would be dripping down upon the timer base and powerhead area. If this is the case, replace the stator.
You need to check the compression... what are the psi readings of each cylinder?
Check the spark... it should be a strong blue lightning like flame that will jump a 7/16" gap, a real SNAP! The 7/16" gap is important! What do you get when the engine is quite cold..... and when it is acting up?
Also.... the term CRANK pertains to having the electric starter "cranking" the engine over. Are you saying that when the engine is hot, the engine CRANKS BUT will not START properly?
