One at a time.How can I remove the three cables on the top when I try to remove engine from boat?
Thank ChrisOne at a time.
This is the sequence....
Remove split pin #1. Remove nut #2. Remove 'lower shift cable'.
Remove split pin on the bottom of clevis pin #3, remove clevis pin. Remove nut #4. Remove 'remote control cable'.
Remove nut #5. Remove nut #6. Remove 'throttle cable'.
Chris.........
Thank BTremove the nuts holding the cables in place, move cables to a safe location, remove fuel line, electrical cables, remove front and rear mounts, remove the outdrive,
remove the engine
Do you know how heavy is the engine? There are two kind of hoist can be rented. One is 2.tone the other is 1.2Tone.
That's about 300kg... (I know you're in Europe and don't use antiquated units of measure, like the USA)I think it's approximately 580 lbs with manifolds attached etc.
You've disconnected the drive already?
Or in this case Canada.That's about 300kg... (I know you're in Europe and don't use antiquated units of measure, like the USA)
Where can I find the coupler with 123usd?Sierra 16-2323 or Quicksilver QSL18643A5
slightly north of 125 USD
Thank Chris. I did it according to your guide. How can I know what function it is for three cable. I have marked the cable with No.1 and No 2 and No 3. Hope I will not make them back with wrong cable.One at a time.
Chris.........
I gave you the function in my guide.Thank Chris. I did it according to your guide. How can I know what function it is for three cable. I have marked the cable with No.1 and No 2 and No 3. Hope I will not make them back with wrong cable.
I put in C397712 and it said the serial No does not existWhat serial number are you putting in? (It worked for me perfectly.)
Thank youTry 0C397712, as printed on the serial number label. (That leading 0 is very important, and it is the number 'zero', not the letter O)
