How can I remove the three cables on the top when I try to remove engine from boat?
liusigou
I tried to remove engine from boat. But I failed to remove the three cables on the top. I do not want to damage my engine. Could anybody tell me what i should do step by step?
Bt Doctur
remove the nuts holding the cables in place, move cables to a safe location, remove fuel line, electrical cables, remove front and rear mounts, remove the outdrive,
remove the engine
achris
More fish than mountain goat
One at a time.
This is the sequence....
Remove split pin #1. Remove nut #2. Remove 'lower shift cable'.
Remove split pin on the bottom of clevis pin #3, remove clevis pin. Remove nut #4. Remove 'remote control cable'.
Remove nut #5. Remove nut #6. Remove 'throttle cable'.
Chris.........
liusigou
One at a time.
Chris.........
Thank Chris
liusigou
remove the engine
Thank BT
liusigou
Do you know how heavy is the engine? There are two kind of hoist can be rented. One is 2.tone the other is 1.2Tone.
Alumarine
I think it's approximately 580 lbs with manifolds attached etc.
You've disconnected the drive already?
achris
That's about 300kg... (I know you're in Europe and don't use antiquated units of measure, like the USA;))
liusigou
Today I took off my damaged coupler from engine. What part No. is it? Is it expensive?
Bt Doctur
Sierra 16-2323 or Quicksilver QSL18643A5
slightly north of 125 USD
liusigou
One at a time.
Chris.........
Thank Chris. I did it according to your guide. How can I know what function it is for three cable. I have marked the cable with No.1 and No 2 and No 3. Hope I will not make them back with wrong cable.
achris
I gave you the function in my guide.
liusigou
My engine serial NO. does not exist in Mercury Website. How can I get the diagram according to my Serial No. I'd like to learn something from it
achris
What serial number are you putting in? (It worked for me perfectly.)
achris
Try 0C397712, as printed on the serial number label. (That leading 0 is very important, and it is the number 'zero', not the letter O)
