Drowned Rat
- Jan 20, 2004
- 3,070
Re: Honda Nightmare
Rodbolt, I'm not sure about your theory with the whole nipple thing. If the nipple has an unthreaded portion between what threads into the block and what threads into the filter and that unthreaded portion wasn't treaded into the block far enough, that would be a problem. The filter would screw on and then hit that unthreaded portion and tighten up but not necessarily seat against the block. And if it was close enough, you really wouldn't notice it. PSI is PSI, yes, but this was the first run out of break in and he had just changed the filter. Maybe the new filter gasket wasn't quite as thick as the factory original. Maybe he was running at a higher RPM hence higher PSI. What if at the factory when they test ran this motor, the tech saw a leak at the filter and just cranked down on it more to stop it. As you know the manual tells you to turn until it seats, or in the case of this particular motor until it appears to seat, and then another 1/2 turn or whatever. Just a thought. I can see how this may have happened. Also, screwing on the filter would not necessarily also screw in a loose nipple more. It depends on how much torque would be needed to twist it on. Typically not much is used when installing an oil filter. <br /><br />RB. Has Honda offered to re-imburse you for the teardown if a warantee issue is found?
