Honda bf50 spark and carb issues
Status
Not open for further replies.
Sea Rider
NS, I'm not saying that need to tear the whole crankcase in pieces, what's ideal to do as a preventive internal maintenance is to remove the cylinder head, exhaust cover if having one clean all the filth such as salt layers, salt crusts, rust collected on the entire water passages to pristine clean condition, install new gaskets torqued well to factory specs. It's entirely up to you if wanting to go that route that will asure top cooling in the entire crankcase. If the temp alarm triggers due o an overheat condition after having installed a new impeller defintely that motor is not cooling right. Need to test the combo at open water at full throttle for say a 5 minutes ride, will know if overheats or not...
If the cylinder, exhaust cover bolts and threads are extremely salted expect to break some bolt's heads when being removed, a machine shop will remove them easily. Most if not all boaters doesn't want to go for an iternal water passages preventive maintenence due to fear of breaking bolts and/or the associated hand labor cost if sending the motor to a shop to perform that job...
Happy Boating
Newbie sailor
Finally can get some work in this week. Today I’ll be attempting to descale the internal water passages.
I already have the foot removed. So I’ll be using a large container to hold up to 5 gallons of the descaler. A sump pump with tubing to connect it to the inlet pipe. I already have a larger diameter tube connected to the pisser to help move any large pieces of salt and crust. I’ll just circulate back into the bucket for a while and see if all this helps
MattFL
Master Chief Petty Officer
You won't need 5 gal. I just did this to my 50 (just posted a new thread about it). 1/2 gal descaler mixed with 1/2 gal water in a 5 gal bucket was plenty.
MattFL
Link to the descaling thread:
Newbie sailor
I used descaler from West Marine and with the foot off I used a bilge pump connected to the water inlet. Put the descaler in a big bucket and circulated the solution through the motor for about an hour with it peeing back into the bucket. Put a screen mesh with a rubber band around the bilge pump as to not reintroduce any grim back into the motor
Sea Rider
Assume you removed the thermostat and bolted the cap back on previously running the descaler through the motor, right ? If not the cylinder head area has been just partially descaled...
Happy Boating
lilbitwayward
Also the next time I actually run it will be in a large trash can filled with water. I won’t be using the adapter or muffs and it ensures that the foot is sitting/and getting enough water
That seems logical because fact is you wont have water pressure in the lake. Water barrel and back flushing tal tell hole with air pressure seems like good advice. My tal tell tube seems weak with new pump but doesn't run hot. I read somewhere as long as there is a steady stream its ok. Its job is to let you know there is water being supplied not necessarily the volume . .
Status
