Hole in gel-coat
Woodonglass
Honorary Supreme Mariner
Re: Hole in gel-coat
I use it all the time with epoxy in woodworking. Great stuff. Not sure with GelCoat & poly resin.
Yacht Dr.
Your good to go. Just make sure you break it up before mixing gel into it ( using a scrap of screen works good to do this ).
YD.
SeaRayboater95
Hi guys;
Well, I thinks I have been successful. I'm up to 600 grit and you can't hardly see the patch.
If I want to fill that hole you can see in the picture, should I clean the new gel with acitone?
Thanks guys for all the help........
Ken
P.S. What do I clean the repair with before I pollish.
