Re: Here We Go: My 383 Stroker Winter Project
You know most of the times the thrust button needs to be "adjusted" to make sure you have the right end play. A few earlier post I suggested you get some expert help on this to kinda go over it with you live and in person. Just think how dissapointed you would be if at minimum you spun a bearing due to clearances. Or worst case you throw a rod. for little extra money you should be able to get a pro to go over it with you. Trust me it is cheap insurance. As for the 7/16 studs i think you will be ok. lift and spring pressure somewhat determine what stud size to use. And as for your rockers I have never seen self aligning aluminum full roller. Not saying they dont make them though. A pic you had earlier they didnt look like self aligning. Can you snap a pic of the tip, top and bottom?
At the moment I can't go outside and take a picture of them. Here are the rockers I bought:
http://www.summitracing.com/parts/SUM-G6936-16/
Also, I was told that the spring pressure I have is about 105-108 lbs. Both the original builder and the 2nd head shop I used said that this would be good enough for the cam I am using.
As for the thrust button, I was told by the Comp Cams expert that everything would work the way it is, and when I looked at it I saw that the timing cover actually had some sort of shim attached to it where the thrust button touches, in addition to the thickness of the wear plate that I used. I assumed that the shim would be sized to correctly set the end play. The thrust button that came with the kit is actually bolted to the upper cam cam gear and cam holes. If it's really necessary then I could take it back to the builder and go over it.
