help with hydroelectric shift switch
mnmurphy
my electric shift switch has been fried on my 72 100hp johnson outboard. i find these are hard to come by... but have read that a 3 way toggle switch can be used instead. does anyone know if this will actually work or should i hold out and hope to find the correct switch? thanks
R.Johnson
Re: help with hydroelectric shift switch
If you can, go with the originol switch. I know people have done it, but that toggle switch on the dash is an accident waiting to happen. One of my little grand kids' would see to that.
tashasdaddy
very true, there is a disclaimer in the thread.
mnmurphy
thank you all for the help. now that ive read into it some more, it doesnt seem like a very bright thing to do.... not to mention my daughters would surely try to play with it. a nearby "mechanic" told me i cant replace my box with an evinrude push button console... that they arent compatible. is this true as well?
R.Johnson
No! it is not true, The box from a hydro-electric engine will work, It's just that there box used an exsposed switch with 3 buttons.
patrick4266
i have a 1972-85 hp evinrude and it uses the selectric controls which is the push button. I believe it would work on yours too.
tashasdaddy
the switches and boxes were different, but both will work. they do the same thing. just different designs.
patrick4266
Just curious, do they use the same plug to plug into the motor wiring harness?
mnmurphy
okay now im confused... i decided to use a toggle switch until i can find the correct switch i need. but all the directions i have found about rigging up a toggle switch only talks about green, blue, and battery wires... i have wires coming off the original switch. 2 white, green, purple, and blue.... how am i supposed to hook all this up?
R.Johnson
Those wires' keep the engine from lurching into forward when you shut the key off, just amongst other features that toggle switch won't have. That's just one of the reason's we told you not to do that.
larky
I thought I read in another thread about a 1972 hydroelectric shift, that the white wire was for the "start in neutral only" feature, not present in the 1971 models.
jay_merrill
I believe that the confusion on the pushbutton type controls is that there is an ERude version, designed for the hydroelectric shift that works fine, and there are other OMC pushbutton controls that were designed for other motors. which won't work. You just have to make sure that you have the right one. One way to tell is that the plug on the end of the wiring for the hydroelectric shift model will be yellow if it is the original item.
Be careful of trying to rig your own system with a toggle switch because there is, indeed, a lockout circuit that prevents to motor from being started in gear. There is also a blocking diode in the circuitry that needs to be included in any home made design.
You may find the following link to be informative but please read the whole thing because it took us awhile (and a few mistakes) to get the system completely figured out.
http://forums.iboats.com/showthread.php?t=240278+1972+johnson+shift+switch
