Re: OMC V8 setup questions
DHadley, thanks and heres some more info
<br /><br />The setup is on a 1985 38 scarab raider. Its the old Miami Vice KV hull - except setup straight from the factory w/ outboards and with better colors. (Ive heard they only made a few of the outboard 38s.) The last time it was run it had twin Johnson 275 V8s - I have come to realize one engine was a 4.0L, the other a 3.6L. The 3.6L seized up and I have purchased a dressed 4.0L block to go on top of the 3.6L mid section and lower unit. <br /><br />Ive read from posts here that these motors like (love) to rev up to 6200 - 6700. I cant remember what rpm range the boat turned but I think WOT was somewhere between 5400-5600 and we cruised around 4000-4500. The thinking was that this was the correct range and they would last longer it they werent pushed.<br /><br />I dont know why the 3.6L seized up. The second hole up on the starboard bank is the one that locked up. I had the carbs completely redone and the correct gas line setup on that motor as you described (the 4.0L sides elec primer was broken and we ran a pump bulb - and will now be removed.) <br /><br />For the new setup, I was planning on removing the VRO oil pumps and running premix at 50:1 with ams-oil.<br /><br />They are the 25 models and I believe they are the right depth but havent played around with that at all.<br /><br />The props I have are big ear chopper props, 24p. I am probably going to run it with these props and see what I have. If this thing has been maxing at 5600, dropping down a pitch or two would be a wise move
