Help transom leaking
Jrato14
I am ready to run for this thing. We launched the boat today and this is what’s happening.
  • IMG_5506.mov
  • IMG_5507.mov
so, pull the drives, pull the motors and fix the transom
Jrato14
I’m going to have someone work on it but he is saying could be bellows
Have you pulled the drive for the annual maintenance and inspected the bellows?
cptbill
Transom, bellows, Y pipe, Scotts right pull the drive check the bellows then pull the motor
Donald0039
It's good to pull the drive(s) one a year especially in salt water. You can grease the spline, u-joints, inspect the bellows and kind of makes sure the drive does not get stuck (corroded) on the transom assembly.
Jrato14
Hi all good advice. I tracked my leak to where this raw water line meets the transom. It’s hard to get to but I’m wondering if it is just loose or something
Jrato14
Just checking to see if anyone has any thought if bellows can leak here. I am having them done next week just hoping that could solve the problem
Jrato14
I am not doing it my question is could the bellows be causing that
BRICH1260
It`s hard to see a leak in the pic, but a leak anywhere on that hose would not be in conjunction with a bad bellows. The bellows could still be bad and need replacing but if you see water from that hose, it would not be bellows water.
HiWard
That’s the hose for the raw water to enter through the transom in to the power steering cooler. I also have a small leak on the transom end of this hose, only when engine is off as the suction from the impeller will not allow water to leak when running. Water will drip from the hose barb onto the Y-pipe of the exhaust and into the bilge. Did you try to tighten the hose clamp(s)?
ESGWheel
Ensign
That is great got to the issue.
And suggest some follow up: improperly placed clamps (as well as overnighted or wrong type of clamps) can cause premature hose failure. A clamp tightened straddling the hose bib like the mockup below can eventually cause a failure at that point (blue arrow). And lot of bibs cannot accommodate 2 clamps, unsure if this one can. Suggestion is to REMOVE that improperly placed clamp. Here is a good article on hose clamps in the marine environment: link.
