I have 50:1 ratio, I put in oil first think i would get in 10 Gal of fuel, but only got in 7.4 gal, could to much oil be cause of not starting now? , EDIT
hey great, engine will just turn over, but not fire off, just floods out, i am stumped, we jus had it out last week, ran fine, now i at wits in tring to figure out whats wrong.
oil isn't the problem is what he is saying. check the safety strap, primer bulb, choke and such...
carbed engines with a VRO run a variable rate of oil... 50/1 is the "standard" for safety at WOT and Idle.... but it will run with slightly more/ slightly less just fine.
