help to much oil
ed45223
I have 50:1 ratio, I put in oil first think i would get in 10 Gal of fuel, but only got in 7.4 gal, could to much oil be cause of not starting now? , EDIT
M.A.CCruiser
Re: help to much oil
oil isn't the problem is what he is saying. check the safety strap, primer bulb, choke and such...
carbed engines with a VRO run a variable rate of oil... 50/1 is the "standard" for safety at WOT and Idle.... but it will run with slightly more/ slightly less just fine.
Ed, We ran 24::1 in the fifties and early 60s, and 16::1 before that. Too much oil in the fuel is not your issue. Do you have spark?
