Re: Help please. Computer reboots on it's own?
I had been fighting this problem for the last 6 months on my basement file/music server. This computer also has the printer connected to it.
Every day or so the computer would be off. I would notice it when trying to ftp in, or get to my files.
I was about to take it to work and start babysitting it while swapping parts as 386 did.
Then one day, I was downstairs when someone tried to print. Turns out, the ups would flicker for a second when the laser printer would go into warm up (1800kva ups) Turns out the batteries are shot.
This took a LONG time to figure out, because the computer would receive the print job, send it to the printer's memory. The ups flicker was long enough for the computer to shut down, but not long enough for the capacitors inside the printer to die and loose it's memory, so it would still print that job, but the next time you'd go to print, nogo, machine was off.
Personal experience for this problem has always been ram/motherboard/power supply. If you find that you have a bad ram slot like 386's had, one option is to jus put a larger stick in the other slot. This is an option for a home computer, but not a good option for a business computer.
