Still sounds like a Fuel problem. Are the plugs wet? Are you still getting spark? Can you use a spray bottle of pre-mix and try to start it and will it run if you do? Could be the reeds if you got it to go by putting fuel directly into the cylinders(Not through the Carbs).Teaspoon of gas was put in each cylinder. It ran fine while that was being used up. Spark is good with the old pack. Put a primer bulb in fuel line, but before the VRO/fuel pump. Got it to fire but not run. Just a 1 or 2 second run and stall
