Re: help! Now won't start
You have a crossflow. You say you replaced the powerpack with one from a looper. That will work BUT the wires in the connector plugs may be in a different position resulting in a different firing order.<br /><br />The pack has 3 sets of wires. One (orange) set goes to the coils. You say those are on correctly. The second (brown) set goes to the stator. Those are OK. Just follow the third and only set left to the rubber connector plug and see if the colors line up in each plug (blue to blue, white to white - whatever the colors are). If 2 are crossed the firing order may have changed from 1-2-3-4 to something else like 1-3-2-4.<br /><br />You can also check the firing order with a timing light. Mark top dead center on each cylinder, number it on the flywheel and spin it over while checking each cylinder to make sure it has spark at the right time.<br /><br />Look at the wires and let us know!
