Hello new - boat repair questions (deck)
Okapi
Hello I am new with a ton of questions. (Please forgive me as I do not know most/all of the boating terms, but I will describe the best I possibly can) So I just bought a 15 foot 1975 Glastron for $400. It's gonna need some fixing up (but is ready to run on the ocean/lake but I wanna make sure it's in tip top condition), came with a 75 hp Chrysler engine, which I was told works well. After checking out the boat once I got it home, I noticed weak flooring so I decided to dig some up, lot of floor rotted. It's not a big deal to fix, easy enough. I looked all over the bottom of boat and there is no visible cracks etc that would leak in the boat. Now I located where the water was coming from (ripped up all the carpet as I plan to put something else down). The catch in the back of the boat where the drain plug is located, the area surrounding the water catch has two holes, one on each side. They seem to belong there, but I am not completely sure, I can provide pictures if needed. Also, I'm trying to decide on what type of floor to replace it with, and if anyone knows a good place to get the wood I need to lay down before putting a product on top of it that would be great. I don't really live near the ocean areas in California, I'm about 2-3 hours away, but I got quite a few lakes all around me as I live near quite a few national parks.
Also I have not decided if I want to actually paint the boat, but I am leaning towards it, but I prob wouldn't do it professionally, it'd be done by me cause I can't see spending that type of cash on a boat of this age.
Any thoughts would be great.
RWilson2526
Master Chief Petty Officer
Re: Hello new - boat repair questions (deck)
Welcome to the forum....you have ALOT of questions there and not sure really where to start.....I'm not entirely clear on your statement about the "catch" around drain hole letting the water in to rot the floor? The 2 holes you are describing sound like the holes in what they call the stringers so if water gets into the bottom of the hull (bilge) outside these stringers the water will be able to flow into the center of the boat and either drain or get pumped out by a bilge pump.
I'd start some research in the repairs section on floor replacement. typically a new floor will be marine plywood and then coated with fiberglass resin to water proof....all depends on how good of a job you want to do....if you dont plan on leaving the boat outdoors uncovered you could probably get by with some plywood, pain and some outdoor carpet over it.
Again...start some research and keep your questions to one at a time and you will find tons of good people here that are willing to help
veritas honus
Okapi,
First off, Welcome to iboats! You'll find a lot of great people with great knowledge here. I'm not one of them;). If you havn't already, please take a boater safety course. Your deck issues may be more work than you think. When you've got a rotting deck, you may very well have rotting stringers too. The stringers are the "ribs" of the boat, so to speak. They support the deck. Check them very carefully to make sure there's no rot before you replace the deck. Check for softness. Probe with an ice-pick or screwdriver. The wood/fiberglass should be hard, solid and dry. If you find rot, you'll need to address that issue. Look for any waterlogged foam and foam with old waterstains. Stringers can be repaired and or replaced if necessarry. Check the transom for rot. Post some pictures. Let us know the model and year of your boat and motor. The more info you provide, the better we can help. I think we all love to see pictures of other boaters projects.
Safe and happy boating always!!!
Okapi
The stringers are rotted, I didnt know what to call them. Well, I found this product you can put over wood that seals/waterproofs it that I was thinking about using. I won't be using carpet again as some of the water damage I can see is clearly from it. The boat will be kept out of water most of the time unless in use.
veritas honus
How badly rotted are the stringers? Post some pictures. If it's minor spots on a couple of stringers, no big deal. If all the stringers need to be replaced, it would probably cost less to buy another boat. If you repair them, don't seal any rotten wood. Make sure you cut out and fill any rot. Then you can coat with fiberglass or epoxy. There are several resources within this forum which will provide excellent guidance. One of the Moderators is probably going to move this thread to "Restoration." Use the search button to find other threads on this same subject. There is a great tutorial on fiberglass work with stringers and decking on this site. I've been trying to find it; but no luck yet. I'll keep trying.
Okapi
I plan on removing all the deck, the boat is a tri-hull, so there is not much deck to really replace. Plus after that I will know for sure how damaged everything is. I am at work right now, but I will take some pictures when I get back.
Welcome aboard and best of luck. You have a job ahead of you I am sure. I did the same thing a couple of months back...bought the boat and said, "What the heck! Dig in!" What a mess and a challenge. There's a ton of info here AND a ton of inspiration. Just keep searching and reading the other postings. The one thing I can say is that you don't want to just seal the stringers. You will need to take your time, dig into it, and do it right. It's going to be a lot of work and sweat. Don't take short cuts on time or money. If the boat needs it, do it.
Steve
http://itisjustmyimagination.blogspot.com/
