Hand Wheel Coupler Works Way Loose
E_S_A_D
I just don't know why. It works its way loose no matter how hard I turn it clockwise to lock. Maybe it's old. I can't find a cheap replacement part either. I'd love to switch to a latch coupler, but not a welder. Not sure.
81_chapparel194
Re: Hand Wheel Coupler Works Way Loose
they make bolt on couplers. just use good grade 8 bolts..
E_S_A_D
Would I have to somehow cut off the old hand wheel end them drill holes for the coupler to bolt on?
E_S_A_D
Actually I think mine is missing that lock, how's hat work? No idea on brand.
MH Hawker
Yes it is missing the lock to hold it in its place.
E_S_A_D
How does that lock engage or disengage? Also, where else can I buy this online. That sit charges $11 shipping for a $1.590 part...
MH Hawker
The ones I have used in the past had a leaver thing that was under the wheel that was sort of a spring that you have to push down on to allow the wheel to be turned, the leaver locked into slots on the under side of the wheel. You may be able to buy a full coupler for the parts. If I remember right the shaft that the wheel goes on has a cut away flat spot and that is what holds the leaver in place.
Like this
E_S_A_D
What do I need to do if I want to replace the old coupler with the colt on latch type?
I assume I need some type of hand saw? What type? To cut off old piece.
Drill bit- what size?
Bolts, bits and washers- locking washers? What size?
Sounds like it may need to be done in a shop!?
E_S_A_D
So what is the minimum type of bolt I'll need and what size for the trailer coupler? Length and width? I have no idea on this type of stuff, ugh...
Here's my plan as of now:
Buy hacksaw, cut off welded old trailer coupler hand crank that is junk. Put on new coupler. Drill two holes. Bolt on with two screws. Done?
E_S_A_D
Another stupid question... if I buy the coupler are trailer sizes pretty standard? Should it fit on the trailer?
MH Hawker
To size it for a new one measure the existing tubing its on, then start hunting.Their sized by the size tubing its bolted or welded to and the load it pulls like A CLASS 2 , 3 ,4 or 5
E_S_A_D
Is it possible to switch out the hand wheel coupler to a new latch modern one? Is it tough or even possible?
It's just a trailer end with a 1 7/8 spot for ball. Can the hardware just be taken out for hand wheel and switch to latch or am I way off???
E_S_A_D
Since its nowhere to be found online. Anyone have a MCGiver like suggestion to keep the bottom part of coupler attached to top of handwheel with missing spring and latch lock???
SWD
When it comes to towing, no mater how big or small, safety should be at the fore front of your mind. If you cannot guarantee that your trailer will be safely and securely attached to the tow vehicle then its time to get a new coupler unit. Get it fixed right and you wont have any more concerns.
E_S_A_D
I understand this. I need to tow it to the shop at least though. Therefore I need recommendations based upon my questions.
SWD
Could you perhaps post a pic and then it may be better to make some recommendations?
