Glen-L WB Power Skiff Build
zool
Looking good Zool !
I need to replace the motor on my table saw .. It went out a good while back . Need to get off my rear and fix it ..
Alot of times the motor is more than the saw is worth....I thought I had to replace this motor, but i think the blade was just warped and binding.....the Ryobi was smoking..so I know thats gone :D
oldrem
Friend of mine put one in a couple years ago - retirement present from his wife
zool
Update:
Made some more progress today, I set the center bench supports into place and made a bunch of small cleats to temporarily hold things in place til I could start pb'ing them in.
y4mjb23FhB63guyg0cLEOXU6Eb1G5IpOWlmrlfOEr-fwRmu_1us6OmnHSjkItuy7P9VMQ4-b8AeGHbttgZ0m_kWDkYpsbGJ2lsbZgfyBAHIdLXjDxdiYL5UfbEurdFMuPtiZl8WEgGTKP8_rWiMETV7gM-8XPl6hzRS6INrHWQVQIVHgtIDpdrUZAHIR7euTny0EIcSa9MqvfcvKz60A3at0g
y4mKw2J3TWdhmQyZPClvlOPwKDAUid3p6KKGVv8EirEl9sYwhMgLe1ktdQa71UER1v6wABO4PDW71DxKWSbqnkWbnGMiztMHMm8FmCL4dCYNY_nzIHW4XZMovrMhIC5TneP-mfvUwFI05919eMOZ-WJ4g6iw_DwSmm3025LQgXFHI9_UYI-4v8eLskQF1cohNrW3JlhOodlzt5Yi9I7EnVAzw
Then I fabricated the rear supports.
y4mCgzEIbii6TcypdsErvyf9APBfHBbeaGI3bZ5vpNkqIMr5vh9rHz45gLrv8ZoerGZK8PTik5VhNJ86pXPqR6jQVRC300x8YSvDrrWSGXf5ZndhsEVB-2yY2BemkU-PDRf43UQ0Mm9NJXoUdKiQBRHJzph8oaDEYxzvYn9JRRbE3KDBCmnMwUXsKphupJ18gUCWMUlIMULDEnFliGBAQAKow
y4muLzp9NwoDOa9QHM_ZlBFe9W_D9qm6nKkzKAiBTFvtUjow4WVEtb2Abyiy75nnLt2_cRka26fzhaptbMMcyJ8c2hSuc0FWVQLxlezlgLEHKOHtfpkYZyP7z1i0SodiLErsWyxYPOnyZxVtT0MOXmkrTsK57KwVMLQU1rAUbGqXoKRW7RwA4I_WHw8HN1ogbnjo_ZWsOkmJyUvdj7pPNysGA
y4m_YiGiY_xfblWw5FvSCN3yU3_OuWQQgrdM2CGo7BI0HFZavbId0ueaJXRV64z-jdOIv8tJCVdbhfg242TtjI9rwJcy_lhqheKz0WgrUUsqUfSiH6h7sHKlccyMRY_TgnnryfeRQIaER7cvc_EdDmpAMRLJK-8dNKKANU1nOHggTRj_eXaOP33P6l6Y2j_YvEyUpEtMd2XfP4pNfdYh_EBVQ
zool
I pb'd around the cleats, once it cures, ill remove them and pb the rest of the seams and tab them all in, along with the deck.
y4m2Ap1DOgbJ_CinStIha1CEDz1LzOvR8emsXcEtDD3Cs2Cz8PiQtu8SMviSNc3pvzKwCuJ-eewZqAp_oU5KgFohedA1waXtmxycX6quAQC6zBRHWOtC2eAcCQWd2IhgqJoQnKzijZPB3Wre60M9HIngNdCgbY_E9ZktZbNxlZO67yhwiL7J8YBC9q0msmp2YTEPmoQ48u5gtsaZJDsSe5H_w
y4mE7Ru-5BZ9Iv9_UEXqf2mI65eSSjgLPU1J1OkUoHNI2A-HxdgZ_--2TdfCcNS94iF0nu1LDGGUjfzG9u4OQkWo3Wl5Rbm1Z2neoyfeFcW_2rajiVRvA4ZlK1XVDNuxnz72VUHlKN96ntInZNJXVJSRGLOfAMi2Bs1lffOdk59HzjyW4WhnJz_rZwnpxqq9EQwRb9mOUfIv1hFSxGZXzBr8w
zool
Thanks Guys,
The 2 rear seats will be wet areas with a flip up seat cover...so i added limber holes at the transom. I also had to loosely place the lower inner transom plank now, so it could be one solid length.
y4muHp-G0V5G_SZ0fUHsnnWu7SQvltquARNfL94xeFg7WUQLwsHyV1WvAbAgrRg_wipCcPM9SG1CwjpJk1Nq95zuzYxX5zV4LH5ozv3T4SyY24d9TnwAXTpCHQeOEECMvFxWTMujRKBcs1zBiIFYWyrWQ5ME6BYmWtoTGcvMVAwOPonowYBaMgxlD_yge4Jgqayv5hsbw0bScT5iEg05VjZbw
y4micm6T7AeV2CPdh1rznb1bnK5O6pusqyiq66UapAODpzTEo_zwsy3Li2pyIAPyfFG67cQfpyl7Zf3kb3cTp2h3i2Mg5i0N2UPSyFl2lOiOVcKep2C1RfEJzHo9neVqGqVK-0Guh8XQThN8xARF29RKNbjBkFnxqhmtEICZZZFpoYfbCwHqxLvKz527nGNeI6SVYuTstCEnRwndxDxgiJQQA
Im routing the edges of the planks to give it s defined plank look. just used a round over bit.
y4mijytHMLc10U_r-2XStzt965s6N5XcztNfuWnPtdhSOZkFQR_fthRXQBFHiOtZRMXxI7XbZ6uokIsMDmbVF_A3Y0c4ZEjIFh4CUtdnLQAa5WJdIw6TDpk7wGkDXxtcMc1QfPqBrDPW0-jdhFFKL4OLnv9fKksK8PXqLAQngRqpwsA-kG8kUDWfPERzhZ1F7AoWOFdiXkSXqOirG2IBJCnRQ
zool
Thanks guys, at this point, im just making it up as I go along..and making some changes to the original plan.
One change I'm planning is to change the white color, the Rustoleum white is just too stark. Im probably gonna go with Oyster White, they have it in the Rustoleum marine line.
Anyways, I went out there today and removed all the cleats, and pb'd the remaining seams, and let that set up.
Then I started fitting some of the trim boards to see how they mock up.
I took a 1x4 oak board and notched it to fit over the hull edge.
y4mc3HAC2lS0r63nCD77HHYnYFM6sefTeqRJy_g_kE0I4MUPbFLEGqvucsBx5ldgAMB2i3rjziAKRaoLspVUINL21Ta_V4_8UaZU8m3XiwoP88iFSB-EMhmGg3JZ8p4VN-GHVlazuMVN0KSC2wELJ-1xJEnB7nEJ90IWA-wfyz1POPvqi7oExrDdFFPvrSFgQr0jdCNIWbpisjmEMlieOxXzg
Then I rounded over the top lengthwise. This board will serve as a termination point for the inwales, as well as a grab rail and to keep water from pouring in from the bow.
y4mNXgvYSi2vuqomIcuTpolIInx58oZbliqyCWlmauko00iLZROd5i6idZ5LnM_tL35myfeSiNxv3F43ju9ls_EzJ01QfB_qtjJkkDjxIGYK5pRfk34Ji8H6FRrgi4SnO-oTfCVIjUYnIfPper1POPu2Upc2tNlvoTntRNz_7nuajAiIrnprECA7fG98Ta5YP_qgbOFwlv4lfM2ggOIGEDbzg
kcassells
The oak is gonna look real nice. How are you going to finish it? Wishin I had more fine wood skills. just saying.
zool
I also rounded over the edges, needs a bit more sanding, but its almost there.
y4mtGstaPk8cgQ8b5DLLDAOD1LbSP7kI1_BO7KP7O8C6BKzHY-8JKyWXJ60bHVvWZypKjsz4ZUt4FU4nFwysYf9jfQxB7liCBX-ZtIuuE3A9azpLa3P1RUM3S4meN5QacHHrFlwRraDcyNAAO8GCNzFkGUk2hNSJreSytwxLwa3yJFCi6CAE5mR4ckHA4-G6cWQcOEqoHMuHvf6UEMHwCI3gw
I then took some 1/4 oak and set it on top of the gunnel and traced the shape from underneath. I cut it a little wide so I can use the belt sander and level it to the hull edge. Then in 1/4 inner inwale piece can butt up against it flush, and be camped and glued along with the out wale board. Between the inner inwale and outer inwale, will be 3/4 spacer blocks about 4" long each. (have to do some math on the exact size of the spacers to net out to 0).
y4m5MY7U9DJHvrcVk1NHx9I9YfXTIXz2dJ8E5rjtbsr3YOuFzgxH1hQKNtgh9VWdDu_JTj5Cp0k0SBPjT8BOFYa61WzlMrYeil_HXBmV_yMLK3q1ucAbNRFMmhoBsa2BFm6FJcDPxBk6f6w_3I58JesFE3MHJXya-ASIt5byJkUcmecrhlzi8QO-I3z9ljig_6heqoNuQG4FlY789dsZMJ9SA
Here you can see my wavey cut with the jig saw ;)
y4mMbhXpMjIWj0-Lf0alEYTO8LNz1PM6BxTCL9GBthv5yQO9Kynfoi7DBCnrCg2KmrH3Cghz-6KIoCtc-k3vb9MFjGa_57sb1kpLW0UCO76kDeV-MNSfKYBPblVLINSsdLUVsBC1k3MyCAWc-sLGv4s0eAHgnk9shiV3jKULAaykKrHM-PKHxpcjlabXLjZVTJF2eI-jLPHeU_VwsV8heVLBA
y4m62X-Vsf8Ap4QhsVEjHJZ9eRCxpxHiuMAJAfr2WJOTRgRnst-yglTRk4VAk0bRZzOGFrteK8iQAL4gTZqMDyW5PfFrSV8Fv1-PFd9Eg67I-e8QmwHwy-85LdgIp7fEvlu1dlh3AIA9WAju2BTDMB_e-O3m90SVvPtQIkY0zPQRwLwQk5ciZ-EBXAFFGZ1LKay9oCDqx84gmAveByjQynnlw
And they will terminate to the new mid board.
zool
Im leaning towards Black Cherry stain and high gloss varnish...Will compliment the green hull and off white.
kcassells
CUT it OUT! Shut the Door, what..........................................too nice! ;)
