Glastron fiberglass floor with snap-in carpet
G22inSC
Just wandering if you can hose down / wash out the fiberglass floor in the late model fiberglass floors with the snap-in carpet. I didn't know if this was acceptable or frowned upon. I just kind of figured it was ok and the water would drain out the plug, assuming you have the bow raised.
brick75
Re: Glastron fiberglass floor with snap-in carpet
Perfectly fine, in fact it's one of the benefits of this type of floor. You should have drain holes for the water to empty through (mine are in the back and driain to the bildge). Just have to watch out for debris that can clog them up, but that's usually pretty easy to clear out.
yamahas
Exacly, I do it all the time.
sabre2up
I'just did mine. I was told by the dealer that is how they clean them
