wienermobile
Thread starter- Joined
- Apr 12, 2009
- 5
Ok first post, first time on forum, first inboard motor. I just purchased a 1982 sunrunner open bow. It has an OMC V6 original motor, 760 hours and seems to be in decent shape. The guy I bought it from says that he just had the gears in the outdrive propeller replaced by a licenced mechanic. Every time I put the boat in gear it would make a loud grinding noise. The noise is disturbingly loud when out of the water. The guy who sold it to me said to just start the boat in gear to avoid this. I dont really believe this to be good advice. the gears grind every time I have put it in drive or reverse.
**I always used "muffs" when running motor out of water**
I took it on the water for the first time today, started go0d and I let it idle in neutral for 5 min before putting it in reverse. I put it in reverse and heard no noise from the gears. I gave it gas and we went nowhere. I revved the engine almost to redline and the we just sat there motionless. I then turned the motor off, put it in reverse and started it again just like the guy told me to and nothing happened. After a minute the throttle was engaged in reverse slightly (maybe 2 or 3k rpms) and a very loud clank shook the entire boat and we started spinning wildly. I started it up again and it drove forward fine. we went out about a quarter mile and I noticed smoke coming from the engine. Lots of thick smoke and a small fire developed. The wires to my hydrualic tilt motor were melted because they were touching the engine. This didnt seem to be the only source of the smoke. There was smoke on both sides of the engine and smoke coming out of the brass wing-nut coolant drain under the motor. Please help me
Thanks in advance.
Thanks in advance.
