gelcoat repair
Jcris
Hello everyone,
I've got a 1996 Glastron fish and ski that has a bunch of screws holes in the gelcoat that I'd like to repair.
What products would you recommend? How can I get a finish that looks like the older gelcoat? None these repairs are structural.
Here are some pic's:
Thanks,
Jcris
Most of the holes are from screws, some are from equipment removal and some are damage to the gelcoat as in the first photo
Mix up some pb and fill the holes. Then get a gel repair kit to finish
thickened poly resin. (do a search for peanut butter on iboats)
gel doesnt stick to epoxy
ezmobee
I recently removed a VHF antenna from my boat which left a bunch of holes similar to what you're dealing with. I filled the holes with MarineTex and carefully sanded it down. Looks pretty darn good considering I didn't mess with gel coat/color matching/etc. You have to be looking for it to see where they were.
Woodonglass
Ace Hardware sells a product called PC-11. Basically the same as Marine Tex. Easy to use and would be my choice. It's white also so no gelcoat would be needed.
