Gear oil in drive shaft bellows?????
Jeep304
I have a 1986 sea ray mercruiser outdrive. I was getting gear oil in the bilge. I thought the gimbal seal was bad, I know bearing is bad. Took it apart and the drive shaft bellows had alot of gear oil in it. My understanding is there should be no oil in the bellows. Therefore I suspect the inner shaft seal is bad. Am I correct?
Jeep304
Re: Gear oil in drive shaft bellows?????
I bought a perma lube gimbal bearing. I shouldnt have to replace the gimbal grease seal then correct?
Jeep304
Thank you
The seal is ordered.
