Re: Fuel pump problem.
It can also be defective check valves in the fuel hose from the tank.
If you have another fuel hose give it a try. If you don't or this is not your problem you can disconnect the fuel line to your carb and pull the starter rope (make sure you disconnect your spark plugs so it doesn't start up) and see if fuel is pulsating out that end. If it isn't it just confirms a fuel pumping problem. Now disconnect the line to the fuel pump at the motors connector. Put that hose into a jar of fuel and pull the starter rope again. If no fuel pumps then it is a fuel pump problem. If fuel now pumps it is a fuel hose, tank or fuel line air leak problem.
