Floor Storage Support Flange
Stinnett21
I want to "paint" or otherwise restore the support flange for my floor storage. Obviously a high traffic area and sometimes a cooler may get drug across it. I assume a rattle can ain't gonna cut it. Appears to be aluminum. What would you guys do?IMG_3688.jpeg
MikeSchinlaub
First, take it in to either a paint supplier or bodyshop and ask them to try to match some urethane single stage.
Then sand it all down, clean it, spray sealer, and paint.
Stinnett21
Thanks Mike. Pics of your work look awesome. A few questions if you don't mind.
1) "Urethane single stage" is what I tell them I need?
2) When you say "spray sealer" do you mean a primer?
3) Should this hold up over time given the traffic.
MikeSchinlaub
Yes to urethane single stage because there is also acrylic. I haven't sprayed much of it because by the time I started we were mostly using urethane. I've been told though that it doesn't hold up as well in both durability and shine.
Sealer is like a low build primer that you don't have to sand before tip coating. You let it flash for about 15 minutes and can spray over it. You will still have to scuff it up if you let it sit too long though. I really don't see the need for a high build primer, unless you want to fill in every little scratch and sand it down super smooth.
After it's cured, normal foot traffic shouldn't bother it. It is still paint though, so dragging hard/heavy/sharp things across it can still damage it. That's going to be true for anything though, unless you want to make one out of stainless. Even that can still get worn. Nothing is indestructible.
