Floor replacement in a tracker bass boat
Status
Not open for further replies.
Robrote
I have a 95 Bass Tracker pro17. I am in the process of replacing the floor in the front of the boat. I have removed the existing floor. The boat has aluminum supports which are in fine shape. I have a few questions that maybe I can get answered:
1. The floor measures 5 foot X 4-5 Foot. Since plywood comes in 4x8 sheets, how is this accomplished with no seams?
2. What type of wood should I use? I am reading that pressure treated is not the way to go. Should I use an expoy sealer before carpet installation? If so, any recommendations?
Any help is greatly appreciated.
oops!
Re: Floor replacement in a tracker bass boat
hi....welcome to i boats...
lots of deck replacment threads on here ....do a search and read the completed projects forum.
ok....as far as pt ply....you have a tinny (alum boat)
tinnys dont like pressure treated wood....the chemicals in the wood cause a galvanic rection in the alum and it eats the alum......this can be over come by placing a thin barrier between alum and the wood.
the standard for decks is exterior grade plywood....cheap and available everywhere.
however the wood needs to be dryed for a while before you use it....even straight from the mill it is still too wet to get a good bond with resin.
there is no such thing as a seamless deck. but what you do is fiberglass the deck together once its in the boat. this will give you waterproofing as well.
you can use epoxy.....but its expencive.
thiker15
Having just finished rebuilding my Lund, marine ply is the way to go covered with epoxy than carpet. I did alot of research and there is a big difference between exterior and marine ply. One thing that I learned is don't take short cuts, do it right the first time.....
bgouaux
I have the same issue with my bass tracker Pro 175. The walk area of the floor where my seats are needs to be replaced. I also don’t want seems to show. I am looking to apply durabak non skid on it once it is down. What should be used to hide the seams before I paint the durabak on. I am worried about the corners around the floor. What can I use to seal it from water running down the sides and possibly rotting the side wood next to the floor.
Any suggestions
Status
