Floatation foam and rubber bump strip questions
ohfishcat
Well i poped the top,,,tore out everything transom /stringers /floor,,what a job but went well,,,knock on wood,,,,didnt care for the pitot tube going through the transom much ,,,
,sooooo question i have is there any place to buy semi affordable flotation foam the put between the stringer under the floor?
And after that ,,,the rubber bump strip that seals the bottom and top ,,whats the best way to get the rubber back get the aluminum frame,,,seemed like a really tight fit
Bob_VT
Re: Floatation foam and rubber bump strip questions
Home depot or lowes get the 2" thick pink or blue foam which is the cheapest........ and the rubber strip is slid in and fed all around....not easy but a pain
johnsonpeter
you can get more details about foam and rubber strip at http://www.foamandrubberstrip.co.uk/. because they manufacturing the foam and rubber strip and they have many years experience in this field. you can contact them for any related to this foam and rubber strip.
Bob_VT
While we appreciate participation in the forum please read the rules to see how we treat older threads.
Contacting a company in Great Britain may be cost prohibitive.
Welcome to iboats. Please be cognizant of the thread dates ;)
