Fitting a boat bumper
bijou22
Firstly, boat is Wellcraft 21sl 1997 and I have just removed the bumper from around the sides of the vessel, due to the corner being damaged.
All in all there were around 50+ self tapping screws which I have kept. I have purchased a 16 Metre coil of new bumper and will fit this weekend.
How can I use existing holes to fit new one or is it better to drill new holes befroe screwing it?
Any other tips?
tashasdaddy
Re: Fitting a boat bumper
fill the old holes, and use new ones.
bijou22
Whats the best stuff to fill them with?
flashback
I would use an epoxy filler either make it yourself with resin and thickeners or buy a pre made product such as marine tex...either way will work fine and screws will hold in the material if you happen to hit one of the existing holes that you have filled.........
bijou22
Should I screw in or drill a pilot hole first?
tashasdaddy
in fiberglass-- always a pilot hole. using 2 battery powered drills works really well.
sanssouci
Is the coil of bumper stiff,can you straighten it out easily?
bijou22
I can straighten it out quite easily
Mark42
bijou22,
If it is the black vinyl insert, it really helps if you do it on a hot sunny day. The vinyl is much easier to work with your fingers into the rub rail when warm.
Believe me, I know. Took me about two to three hours to do my 14 foot runabout, and my fingers were sore and tender afterwards.
bijou22
Unfortunately I need to fit now, can't wait for the warm weather to come here in the UK.
It is the insert type I have bought and its blue to match the boat.
Any further tips would be appreciated
sanssouci
The reason I ask if it was stiff is I replaced the vinyl bumper on a old Del-quay Dory a few years a go and I couldn't get it to straighten out until I put it in a drum of very hot water.
Then it came out soft and easy to attach. I drilled pilot holes and used countersunk s/s washers with s/s screws. I also applied a butyl caulking that doesn't cure on the inside of the vinyl. Then knocked the round bead into the notch.
Sold the boat and made some dough on the deal because it look good.
Mark42
A couple of 200 watt heat lamps on a stand should suffice. There are low buck aluminum reflector sockets that clamp onto a pipe, etc that are common in the home centers as work lights for under $10.
Pickup up two and a pair of heat lamp bulbs (the type that are used in bathroom heat lamps, or over french fries) and you should have a large warm work area.
bijou22
What size pilot holes would you put in fibre glass for a 6mm screw?
Would you then countersink the inside of the bumper before screwing home?
tashasdaddy
the size of the shaft of the screw, that way the treads bite, and the shaft doesn't compress the surrounding surface.
bijou22
Would you countersink the bumper, or just drive it home, the material is rubber though
bijou22
I will need to add sealant to the top and bottom of the bumper after fitting, any tips or recommendations of sealant type would be appreciated
Saskatoon2005
Master Chief Petty Officer
Why do you have to add sealant? It should be self sealing, no?
bijou22
It should be sealed around the top and bottom edges. The original was.
Mark42
Just put sealer on the screws. Unless there is somthing that the rail is covering that should not get wet, then I would skip the sealer on top and bottom.
bijou22
What about gaps between the rub rail and the boat, I don't think it will seal that tight especially around the bow which almost comes to a point?
