fish accident
eastes
i hit a stingray or dolfin, not sure? but after lost power. i do have slow speed of about 1-2 knots. does the lower unit have a bering or something that would break like a safty device that i could check? need advice .THANKS EASTES. ITS A EVINRUDE 115 HP 1993 OUTBOARD
Huron Angler
Re: fish accident
Sheer pin is designed to fail in the event that the prop strikes an object that pushes back.
My buddy used to break them all the time on his 25hp outboard.
HighTrim
Re: fish accident
Geez the most interesting thing Ive ever hit is my fishing line while trolling ;)
Re: fish accident
That motor does not have a shearpin. It does have a rubber hub, which gives if you hit something. it the motor revs up, but speed stays slow, it is likely the prop hub is bad. A prop shop or new prop will fix it up.
Huron Angler
Re: fish accident
Thanks for the correction, duly noted:)
F_R
Re: fish accident
This is a different prop, but demonstrates what is in there. The rubber tears loose from the brass hub, then it slips.
Around here, people say they hit a gator.
royal0014
Master Chief Petty Officer
Re: fish accident
Stingrays and Dolphins and Gators Oh My :eek:
