fiberglass repair questions
Red9654
once i get the money I'm going to add a new layer of fiberglass to my entire boat for structural support and to stop leaks i have now. but after the fiberglass dries what do i put on it to make it smooth?
tpenfield
Re: fiberglass repair questions
Tell us a bit more about your boat . . .
Probably not the best idea to address any leaks . . . Fiberglass does not dry, it cures. Getting it smooth again would be nearly impossible based on what you have described.
I think it would be best to find the leaks, if that is what you are trying to address. Structural strength improvement from another layer of fiberglass may be minimal to none.
That is absolutely a bad idea.
Go to the restoration section, post up some photos of your boat and include closeups of areas where there are problems. Describe the issues in detail. Then sit back and soak up a ton of good knowledge.
Red9654
repainting boat
repainting boat
after i get out of school im looking into repainting my boat but i have some questions. 1. would adding another layer of fiberglass or 2 to the hull and any structural support? 2. what could i put on the new fiberglass to make it smooth, would that be gel coat? 3. if i did re-fiberglass the boat for support could i do it in such a way that the shape of the boat wouldn't change such as curves and a raised up part on the bow? 4. what paint would b best? 5. what would i put on after i repainted it to protect the boat?
sphelps
Re: repainting boat
Re: repainting boat
Welcome aboard Red9654 !
You need to post up some pictures of your boat so the guys here can see what you see . Chances are you may not need to add more layers to your hull . If it's an old fiberglass boat the chances are pretty good you need to replace the deck ,stringers, and transom before you do any painting . The good news is ya came to the right place ! Lots of good folks here willing to guide you through any repairs necessary.:)
Red9654
Re: repainting boat
Re: repainting boat
i am currently in florida and my boat is in new york so i have no pics at the moment. there is one spot on the keel where i have to re-fiberglass and it doesn't look pretty. and i have to do some transom work too. sorry for no pics
Decker83
Re: repainting boat
Re: repainting boat
SP is telling you the truth.. Before anyone can give any real advice, they need to see what you see..
You may need some repair work done from inside and outside of the hull.. If the boat has been leaking for very long
then the foam may need to be replaced also..
zool
Re: repainting boat
Re: repainting boat
1) adding glass to the inside of the hull would add some support, but you need to gut it to get there, and there is adequate support if your existing structural components are intact.
2) I hope youre not considering glassing the hull exterior..bad idea...applying a new gel finish is doable, but labor intensive, and not needed to paint.
3) ?
4) Paint is just a matter of budget...you could spend 50 bux or thousands..each product/system has its place and pros/cons.
5) wax
