MFG1970
Thread starter- Joined
- Aug 19, 2021
- 14
I know from what I read mostly its, Run Run Run!. Well I got the 1970 MFG 18 foot Deep V for free. So far I have redone the Electric shift
outdrive including new forward and reverse coils New water pump cup and impellor and the outdrive is working very well on land (LOL) Now I have been working on the OLD Buick (Jeep) 225 Dauntless V6 engine. I have replaced the timing chain put new head gaskets lifters and intake manifold gaskets. I replaced the exhaust Heat exchange gaskets Riser gaskets and cleared out all the gunk and have clear passages. I am a bit confused about the riser gaskets closing off the return side of the water flow. I get water into the engine and get water coming out of the thermostat T (4 Prongs) to the heat exchanger. I get water coming out the stringer intermediate housing. I just do not understand where it comes from if the return from the T is blocked off at the rear of the exhaust manifold at the riser. Can anyone help me out with this. So far I have about 1300.00 into this project. There has been some water intrusion into the oil but may have been introduced when doing the timing chain cover. Thanks in advance. I did remove the freeze out plugs and flush the entire block heads and manifold while I had it down.
