Engine turns over perfectly but just will not crank
sunny_fun
Re: Engine turns over perfectly but just will not crank
Spark sounds a bit weak. Your serial number for your engine is a number short, could you check it out?
Sorry about that!!
Serial# 0f760080
sunny_fun
what would cause a weak spark?
LX Kid
Ensign
Couple of things come to mind. One could be the terminals on the coil are rusty/corroded and not making good contact. Another could be the coil is faulty. The high tension lead could be going bad. The points could be pitted, corroded or mal adjusted. Bad condenser going to point set. Inadequate voltage coming off the resistive coil wire that connects to the "+" coil connection. Bad rotor button. Just some things to think about.
LX Kid
Ensign
We need an update to what you found. Did you get a chance to work on it anymore?
LX Kid
Ensign
Where did you go? Still wondering what was found!
