1978 115hp Johnson on a Glastron. Unfamiliar with boats but do car/engine/trans stuff all the time.
Very light pressure from two fingers will stop the shaft from spinning even as the motor is turned by hand. No noises.
*I assume this is a problem and the prop shaft should be direct connected to the engine?
In forward, reverse, neutral, the prop spins freely by hand in either direction (engine off). Spins easier in neutral, FWD and REV have some resistance but easily spins.
I searched but couldn't see where to diagnose past the prop which everyone mentions.
Engine runs fine but prop doesn't spin in any gear that I can see...if it's spinning (i only started it in the water which was dark and turbulent) the boat doesn't move.
Was running fine and then sputtered once, then completely went out about 500 yards later, nothing.
