I have an early 80's Mercury outboard that starts and idles very well. On the test bed the motor runs to full RPM, however when the motor is in the water under load the motor RPM?s are very low ( 1000 -1500). Removing the prop again the motor run well all the way to full RPM?s. I introduced extra gas into the carb, thinking the problem was fuel flow when the motor was under load (i.e. prop on and in grear) and the engine chocked on the extra gas. Compression on both cylinders is in the 130 PSI range. Carb is not out-gassing when running so I?m thinking the reed valves are OK. Spark plugs appear to be firing hot and are not carboned up. There are no signs of overheating. I have not checked timing or the condition of the points. I confused as to where to start as the engine starts and idles so well and seems to be getting enough gas. Also the engine seems to be running fine when the prop is not engaged or in the water. The engine and it?s history are not know but it appears it was not been run for the past few years. Please help with some ideas of where to start. Thank you in advance
