engine tilt problem
jwl04
This morning I attempted to lower my engine. The tilt motor sounded very weak, moved the engine slightly and gradually just stopped. does this sound like an electrical issue or does he tilt motor need to be replaced? Does the motor need to be taken off to replace the tilt motor?
thanks
N1NE1
Re: engine tilt problem
try switching the 2 relays in each others places if that doesnt work you will just need to release the emergency life to put motor in up position to change motor... its a flathead screw on side of transom mount. pretty easy to swap
Will Bark
Also, check the connection of the blue/green wires at the connector just below the relay box for corrosion and poor connection.
jwl04
thanks guys...theres no signs of corrosion, no luck with the relays too..pretty sure the motor is shot..glad to hear its an easy swap out... probably do it this week...thx again
