Engine block direct replacement?
Petermunns
Hello guys,
I have been offered another replacement block/bottom end to replace my cracked block, just can tell if the blocks are the same or not? Have looked at the engine numbers and tried looking at the mercruiser Service Bulletin 2005-08, but still can't figure it out.
Please could some one let me know if the new block I have found will be a direct replacement?
Many thanks
Possible new block
http://i1091.photobucket.com/albums/i395/petermunns/IMG_0154.jpg
My cracked block
http://i1091.photobucket.com/albums/i395/petermunns/IMG_0155.jpg
Re: Engine block direct replacement?
Ayuh,... What are We lookin' at,..?? a 3.0l,..??
What's the question,..??
All 3.0ls can be adapted to work...
Petermunns
Sorry Its a 3.0L block. I was concerned that there may be differances in the casting etc, depending on year?
Ayuh,.. There may be, but it'll be Adaptable....
Petermunns
Ok, do you know if the internal are the same, pistons, cams, crank etc? I am giving my cracked engine to a engineering firm to switch over everything and build me a long block.
