engine back fire
xiong
I have a 2002 bayliner 4cyl 3.0 the engine back fire when running. Just rebuild the carburetor.
Re: engine back fire
Ayuh,.... 'n My guess is, it's Still runin' Lean....
Have ya done an ignition tune up,..??
superbenk
Pull the plugs - are they white and chalky? If they are, you're running lean. Check the timing again and look for fuel delivery issues.
xiong
Thanks everyone for your help, I found the problem the venturi gasket for the carburetor is leaking causing a vacuum leak replaced the gasket and now it runs fine.r
