salvageyard saviour
- Oct 28, 2018
- 170
I'm trying to go the other way. Hoping to use it with a 78 SBC 350. I carefully drilled holes in the 78 flexplate also had to shim crank pilot hole.I have never seen one like that but a very good solution for engines with the small bolt pattern replacing an earlier large style pattern. I used to take the early style couplers to a machine shop so that it would fit the later style engine.
Contact Marineengine.com they seem to have parts/answers. I have a 1969 210 also, however OMC changed their outdrive components in 1969 So it’s best to check through ME’s schematics, part numbers and telephone.Kenny,
Similar question about intermediate driveshaft.
A new to me 1968 210 hp TUE-17R. I can feel slop when I twist the intermediate ball gear. Feels like wear in the coupler.
Will I need a coupler like this?
Also the driveshaft is listed as a one piece shaft and gear (can't find one anywhere). Can I use a newer style 2 piece? As long as the shaft length is the same.
I have 2 early 70's intermediate housings if I have to change the whole thing. I'd rather fix this one though. There is a firm in Ontario Canada that wil provide reconditioned parts, and assemble units. I had my ball gears replaced when I burned them up.
