Deck gone ?
Aircondor
I just got a 16" Magnum mod 151 . The guy I got it from said he replaced the floor about 4 years ago. I found out he ment the plywood over the deck. It was warped and loos so I took it out and . stepped thru the deck.There is a lot of rotted wood floating in the water under the deck, which I just drained. I havent cut into the deck yet to see how bad it is. Guess my ? is .. Is it even worth cutting in there it looks really bad. From about 1/4 of the way from the back to just behind the walk thru ,and nearly all the way to the sides is soft. Well I will be looking at it more this week and will post pix if I can ...
Bob_VT
Re: Deck gone ?
Welcome to iboats.
Until you investigate further..... no one can be sure of what needs to be done.
My first question is where did the water come from under the deck? Is the hull leaking too?
Get the boat onto dry ground and drain it. Inspect the exterior of the hull and then go deeper.
Mark42
Re: Deck gone ?
When you step through the deck and find "a lot of rotted wood floating in the water under the deck", its time to rip out the entire deck and stringers.
Probably the transom is rotted too.
Its a project boat, or a parts boat. Depends on how you look at it.
Aircondor
Re: Deck gone ?
Ok a little more info .. It has dried out some , and I can see that the bottom of the deck supports is rotted. I haven't taken up the fiberglass, covering the deck yet, been raining, to see the extent of the rot. Will do that this weekend if it isn't raining. The transom and all the wood in the rear of the boat seems to be just fine. Just the center third is rotted. Looked at the bottom and don't see any holes but will inspect it closer also this weekend.
Got the thing cheap enough that i can put a few hundred into it and not get hurt, if I can use it a couple of years.
As for how the water is getting in there . There are a couple of holes cut into the deck 2" dia . For what I don't know. They dont line up to any seats or anything else I can think of.
Oh thanks for the welcome and quick response. as I said Ill get more info and some pix asap.
Polyurethane ? will this work to seal the plywood befor i glass and paint it ?
Aircondor
Re: Deck gone ?
Here are the pix after i removed the whole deck, all rotten.last one is all the rotten wood in the dumpster...The stringers ?, look to be in good shape as does the transom. Well next week on to removing the foam and replacing that to... Thanks for all the help . This is my first attempt at a boat. HaHa :eek: I blew a tire on the way home so will have to buy a new tire also. just keeps getting better and better..:cool:
glassport
Re: Deck gone ?
I also have taken on a new project the past 2 weeks. I can honestly say all the search engines on the site help alot. As far as a few hundred I can only say I hope your garage is set up better than mine. Just in safty equipment I have around 125.00 Please use respirator, googles, gloves and cover up well when working with fiberglass. Its not worth your health trying to save a couple of bucks. Good luck on your new quest and I wish you great success. The guys on this site know there stuff, If you can't find it just ask. Oh..! and one of the best quotes I've seen is " BOAT> Bring Out Another Thousand.
GRIND ON..!
Aircondor
Re: Deck gone ?
Started removing more foam today.. Dang that stuff is hard to get out. and the wetter it is the harder to remove. Well got about half the big stuff..
Oh and safety ?.. we dont need no stinking safety ..!! hehe this is a back yard project. so it will look like after done too ...Never worked with fiber galss so i will be asking and doing what is needed...TY
Aircondor
Cuddy Cabin ?
Cuddy Cabin ?
1986 BAYLINER NEEDS SHIFTER BOX AND OUTDRIVE BOOT TO GO TO THE LAKE.
This thing worth 1500$ ????? :confused:
