Cylinder water
Faztbullet
Do u know how water could be getting into combustion chamber if head gasket is okay?
(1) Bad lower crankshaft seal (2) warped head (3) pinhole eroded into exhaust runner or cooling intake(4) head gasket (5)block erosion are cylinder jug.
Will a compression test show anything
It will show if cylinder/rings/piston have a problem(lower compression than other 2)
Dose head gasket need gasket glue
Not a new one and only use a used gasket for testing purposes only..always install a new gasket if head is pulled. You can get away with this on smaller motors
