Aussiegrown
Thread starter- Joined
- Feb 22, 2016
- 10
2stroke 70 hp even rude 98model has water in lower piston chamber. The head gasket looks fine any ideas?
Aussie - Please don't start a new topic on the same problem. Help and advice gets split up and it is too hard for the members to follow your train of thought.
The motor with the nice red line is a 1985 or older 49 cube motor.--Not the same as a 1998 model 56 cube.
Note-----Removing the cover will not allow you to see the pistons or rings.----A leaking gasket will only allow leakage out and not to the cylinder.-------You may find a crack or porosity by removing the cover.
Do waste yer time as your motor is a "foam cast" block and exhaust runners are molded in block...you cannot see the exhaust ports or pistons.
