Cylinder water
Aussiegrown
2stroke 70 hp even rude 98model has water in lower piston chamber. The head gasket looks fine any ideas?
Aussiegrown
Could there be a seal that has gone somewhere causing water into crank case bring water into chamber?
sutor623
Hmmm, I am surprised nobody has answered you on this yet.
You can remove the exhaust cover from the port side of the motor. This will let you see the condition of the piston skirts and the rings. There is also a cooling pathway that flows through just beneath the cover, and if the gasket fails for one reason or the other, water can and will make its way into the combustion chamber via the exhaust ports.
My vote is if the head gasket looks good, pull the exhaust cover and have a looksy. If there is no clear sign of a leakage there, you can simply replace the gasket and see if it fixes it. My guess is that you will see signs of water intrusion. Post pics of your findings.
I do not believe you can see pistons / rings by removing the exhaust manifold cover.
GA_Boater
Aussie - Please don't start a new topic on the same problem. Help and advice gets split up and it is too hard for the members to follow your train of thought.
sutor623
Here is the exhaust baffle that I speak of. These bolts and plate are much easier to remove when the engine is warm, but sounds like you already have the head off. I would be EASY, especially if it is a saltwater motor. If she's a salty, you will probably snap a couple of bolts off, and have to take the powerhead to the press to drill em out. You can try to heat em real good with the torch, and then ease them out of their spots. We got a salty here or not?
racerone , maybe you are right, I may be mixing this up with another one of my motors.........
The motor with the nice red line is a 1985 or older 49 cube motor.--Not the same as a 1998 model 56 cube.
hardwater fisherman
Might have to remove the powerhead to get at the bottom bolts. On my 40hp I got all but one out and I drilled a hole through the lower cowling to get it out.
Note-----Removing the cover will not allow you to see the pistons or rings.----A leaking gasket will only allow leakage out and not to the cylinder.-------You may find a crack or porosity by removing the cover.
Aussiegrown
Sorry a crack in what? And maybe a silly question but what is porosity?
Faztbullet
Do waste yer time as your motor is a "foam cast" block and exhaust runners are molded in block...you cannot see the exhaust ports or pistons.
Aussiegrown
Do u know how water could be getting into combustion chamber if head gasket is okay?
