Cracked Gelcoat
cvtech1
I discovered a 50 cent size crack on my gelcoat that is on top of my transom where you step. I have 17ft Glastron,and need to know what to do. Is this a simple repair or is there more to it than just a crack? Thanks.
cvtech1
Re: Cracked Gelcoat
Will post some asap.
erikgreen
Re: Cracked Gelcoat
To fix the crack probably you can patch the gelcoat. But it'll come back unless you fix the problem that caused it.
If it's where you step, most likely that area could use some reinforcement.
Post pics for better info.
Erik
cvtech1
Re: Cracked Gelcoat
I got the area repaired when I removed the carpet and had gelgoat put down. Will try to post pic later. Thanks.
Spinnaker
Re: Cracked Gelcoat
You will have to grind it out regardless. When the gel is removed you'll see if it is cracked into the glass. If so that also has to be ground out and some glass put back in. Just remember whatever you do with your repair to fill, if your repair does not recede the surface you will end up with a halo in the gel if in fact you don't burn through when you sand it.
